RCU Forums - View Single Post - Complicated flaps
Old 01-14-2007 | 12:42 AM
ScaleME's Avatar
ScaleME
Default Complicated flaps
Could use some help here.
I have an 8UAF. I want to use switch C for flap operation, with center and down positions at various setting. I have done the pmix for each switch position and this worked fine for ch. 6 (flap). However, I can't use a y harness to connect my two flap servos as they are mounted opposite (install requires this) therefore I need to reverse one servo relative to the other. Efforts to link flap channel to channel 7 (other flap) and its control via switch C have not produced results. Additionally, I will want to disable both knob controls if possible (did this ok for channel 7 but don't know if I can do it to both). Running out of pmixs fast.
ScaleMe
