Thanks Ernie,
I'm going to measure the back seat again when it stops raining. Hopefully I can squeeze her in. Like I said earlier, my NexStar just barely fit, I was sweating a bit the first time I tried to load it in the car. That is about 56", so the stick is gonna be a really tight fit. Someone at the local field has one for sale (new in box with new engine), so I may just have to dry fit it before I buy...
Thanks again for the advice,
Dave
ORIGINAL: Ernie Misner
Dave, the US 60 would actually make a great 2nd plane. It will slow down so much for landings that it is almost laughable, and with low rates set (or the control throws dialed down a bit) it can fly very trainer-like. When you feel like going inverted or doing some aerobatics it's still comfortable with the symmetrical airfoil and zero dihedral built into the wing. As you get really good with it you will discover that it does not like to knive edge due to the fact that they have a bad rudder/pitch coupling issue, but it was never designed to be perfect for aerobatics or 3D. It's so good at sport flying though that this is usually overlooked. I think it is the high wing and low stab that does that.
Ernie
