ORIGINAL: infernox
silly putty or bluetak/presstik works wonders, but it sucks to remove
How would i use this to lock a belt ball diff??
Ok, graTao After thinking about it i might go with your way of locking the diff, but i would like some more details. What are the sizes of all the hardware used, and what size drill bit did they use to cut out the slot. And im gonna explain what you posted, and tlell me if its right:
After removing the diff from the car. You take it apart, and on both of those little plastic pieces (not sure what there called). You dril holes/slots. You do 2 holes in each one, and the holes are oposite each other. when you re-assemble the diff you take otu 2 balls, and in the place stick a blt, washer, andlock washer in there place. Tighten them down, and youve got a locked diff.
