RE: Emcotec 2001 RV
Hello,
Well I would not recommend this, only because I do not know of it being tried and it is usually not a good area to experiment with. If the Emcotec (fine products BTW) provides proper isolation to the RX and servos, I guess it would be ok. Also, I would want to make sure the Emcotec balancing circuits still work with the unbalanced inputs, again I don't see why they would not. During start, there is a massive load on that ECU battery, be aware of that and the voltage depression that will cause.
What has Emcotec said about your idea?
In any case you would need to double up your range checks!
Regards,
