RE: gst 7.7 clutch bell
poopsie, any LHS should have this stuff,, diff lube comes in different weights from like 1000 to 300,000, the higher the number the thicker the oil, used in diffs only, I think. The gears in the tranny and such I lube with a light brushing with moly grease, I use an old small paint brush with the brissels cut to about 1/4" long and just dab some grease on the gears. Don`t use much as it will just fly off the gears. I used 50K in my diffs cause thats what I had on hand.Joe
