RE: The BEST Smoke System
okay, i got my pump back and it works good, here is my problem though... i set up a mix to use the throttle and slaved it to ch5, set the curve and it worked great, got to the field and it wasnt working, after playing around i realized this: if i set it up as a pmix with a switch, then set the aux ch to null, it works until i turn the radio off, then it wont work, if i go to the aux ch and put it to a switch, turn the pump on and off, then go back to null, then my original pmix works again, i can turn it on and off with the switch and it comes on when i want to, until i turn the radio off again, then nothing unless i go back to auxch and run the pump on another switch again, then it will work until i turn the radio off again, understand what i am saying i do but what the heck is going on, it makes no sence to me what so ever??????
