RE: The BEST Smoke System
i just read that in the manual i downloaded for the pump, it says to set the subtrim to -100, that will give the negative value, i am going to try it right now...with the pmix, i guess you combine the 1st set of numbers and the atv to get it to come on when you want and how much you want? then just go up proportional from there?
