RCU Forums - View Single Post - Fox 35 needle valve settings
Old 01-15-2007 | 08:32 PM
fox4evr's Avatar
fox4evr
Default RE: Fox 35 needle valve settings
4 to 5 turns out should get it running close enough to be able to set. I usually cut a piece of fuel tubing to run the needle thru before screwing into the body. About 1/4" of tubing should seal it.
Lee TGD
