RCU Forums - View Single Post - 7CP flaps to switch
Old 01-16-2007 | 11:26 PM
Avalanche2
Default RE: 7CP flaps to switch
Hey Kime, I was having the same problem... I set all of mine to switch "G". Up = spoilers / center = neutral / down = flaps.. I did p.mix1 just as you but to "G". But, I also have p.mix2 set as OFST (master) slave 1.. make sure you have (FLAPRN "ON" Ail-2>CH6) I have my (A.BRAKE active) - it shows ON when my "G" switch is up. hope this helps...
