7CP flaps to switch
First, I have 7CP with ACRO mode activated and in the plane i have 2 servos for ailerons (CH1 and CH6) FLAPERONS are ON and ailerons works OK
Flaps (FLAPTRIM) works OK too with VR6 knob.
I want to use flaps with switch but i can't get it work.
I made P.MIX1 OFST(master) CH6(slave) to switch G and RT50% but only CH6 servo moves (right wing)!
CH1 servo stays still (left wing).
How i get both flaps working with switch ?
With AIRBRAKE mix i get flaps to switch E but then i can't use AIRBRAKE.
please HELP !
please HELP !
Hey Kime, I was having the same problem... I set all of mine to switch "G". Up = spoilers / center = neutral / down = flaps.. I did p.mix1 just as you but to "G". But, I also have p.mix2 set as OFST (master) slave 1.. make sure you have (FLAPRN "ON" Ail-2>CH6) I have my (A.BRAKE active) - it shows ON when my "G" switch is up. hope this helps...
ORIGINAL: Avalanche2
That really works. Now I have flaps and AIRBRAKE on that three position switch.
Wierd why flapperon flaps don't work with CH6 only. FUTABA, why ?
