RCU Forums - View Single Post - ailerons & elevons
Old 01-17-2007 | 11:55 AM
ravill's Avatar
ravill
Default RE: ailerons & elevons
Only Ehab uses expo!
Seriously though, I am not using any expo anywhere. I am using the elevon mix on my 10x under menu 22- wing type. One elevator servo, is in the elevator slot and the other is in the aileron slot. I then use an aux channel (not aux 4 or 5) and use my ailerons on a Y, which is mixed as the aileron as master. Trim on.
It has worked very well so far.
Raf
