RE: imac ignition
There has to be a way for the ignition to be killed from the outside of the plane. A standard ignition switch is fine. You just have to have it accessible from the outside (i.e. you can't have it under the hatch). And yes, you want to have the radio set up to somehow kill the engine from the radio as well. Throttle trim or a mix is what most guys usually do.
Hope this helps........Mark
