RCU Forums - View Single Post - bearings of OS .46 AX
Old 01-18-2007 | 01:03 AM
alan0899
Default RE: bearings of OS .46 AX
G'day Mate,
To answer your question, yes you can & should remove the shields from the large bearing, & the rear shield from the small bearing.
Also, the stainless bearings are definately the way to go, they work great & no rust worries.
Check out the Boca bearing web site, it gives you all the info about removing shields.
http://www.bocabearings.com/
