 bearings of OS .46 AX >
Old 01-17-2007 | 08:36 AM
Default bearings of OS .46 AX
been looking for replacement bearing for my OS .46 but all i can get is the 6902ZZ with metal shields on both sides not 6902C3 openbearing and same for the from R6Z the only replacement bearing availble is the R6ZZ. Can i use the 6902ZZ by simply removing the metal shields, same thing with the small one remove one of the shields for the R6Z? thanks
Old 01-17-2007 | 09:41 AM
Default RE: bearings of OS .46 AX
have you checked out these bearing replacement kits specifically for YOUR engine? Correct shield configuration already in place.
http://www.bocabearings.com/main1.as...ide&pg=2&mfr=6
Various grades depending on how much you want to spend. The stainless set would be sure to keep the rust out you mentioned in your other thread.
Old 01-17-2007 | 10:25 AM
Hi!
You can use whatever ballbearings you like ...shielded or not doesn't matter .
Old 01-17-2007 | 01:35 PM
bkdavy's Avatar
I purchased new bearings from Mcmaster Carr (http://www.mcmaster.com). The front bearing replacement is a standard R6 bearing, and leaving the shielding in place won't hurt.
Part numbers at Mcmaster are
60355K35 Steel Ball BEARING--ABEC-1, Dbl Sealed Bearing No. R6 For 3/8"SHAFT DIA,7/8"OD
5972K144 Steel Ball Bearing, Open Bearing No. 6902 For 15MM Shaft Dia, 28MM Od
Brad
Old 01-18-2007 | 01:03 AM
G'day Mate,
To answer your question, yes you can & should remove the shields from the large bearing, & the rear shield from the small bearing.
Also, the stainless bearings are definately the way to go, they work great & no rust worries.
Check out the Boca bearing web site, it gives you all the info about removing shields.
Old 01-18-2007 | 03:17 AM
Thanks guys, unfortunately im in middle east and i only have access the these commercial bearings. sports or hobby specific would cost me arm and leg to ship here. I guess C3 code is rated for hi speed but i could not get the C3 specs but if the mentioned metal shielded would work i dont mind replacing them one in a while cos they're cheap and easily obtainable.
