RCU Forums - View Single Post - Switch Transmitters Blade CP Pro
Old 01-18-2007 | 02:51 AM
GlennisAircraft
Default RE: Switch Transmitters Blade CP Pro
The 9C settings gave max travel on the swash on my PRO - meaning the servos were buzzing (locked up) at anything past those throws.
If you want a more sensitive than stock setup - change the expo to + values - which makes the travel more sensitive around center stick, and / or move the flybar weights in or remove them all together.
Dennis
