RE: Verbitsky's geared engine
I've seen photos of that geared OS 61 before but I just noticed something interesting in the shot of it from the exhaust side. The front housing has been rotated 90 degrees to put the carb over on the side. This alters the crank timing so the engine runs in reverse direction. The gears then have the output shaft running in the normal direction.
