ORIGINAL: exeter_acres
I put the Optical cutoff on my 40%er
I then have it mixed with the throttle cutoff switch..... so when I flip the switch, the throttle barrel closes completely AND the optical cuts power
This year, my club requires our gas planes to stop running when the transmitter is turned off. It's as easy as programming the failsafe on my Ignition Cutoff channel to be "off".
Every gas plane should have an Ignition Cutoff, in my opinion.
