RCU Forums - View Single Post - deans plugs
Thread: deans plugs
Old 01-19-2007 | 11:30 PM
R/C fan-addict's Avatar
R/C fan-addict
Default RE: deans plugs
ORIGINAL: Dokioto
You will be able to do it. It is very esay....
yup you get the hang of it pretty fast. Also make sure to put the heat shrink on before soldering the wire to the plug (I made that mistake a couple time! ) and try to keep it as far away from where you are working because often times the heat shrink will shrink on the wire due to the heat from the soldering!
