deans plugs
Go here and read this thread. It's a very good tutorial on soldering Dean's plugs
http://forums.radiocontrolzone.com/s...8&page=1&pp=25
here's one of my posts from another thread:
"well it's not sticking cause you're not soldering correctly. You should not heat the solder and then let it drip onto the joint. Instead tin the tab by heating the tab from the bottom and then applying solder on the top. The solder should melt almost instantly and form a nice even bulge over the tab. Then take the wire and put it on top of the tinned tab. Then heat from the bottom. The solder will melt and the wire will make connect with the tab. The displaced solder (from the wire being forced to touch the tab) will climb up the side of the wire end creating a very strong solder joint. It's hard at first but it gets easy fast. I've soldered about 20 connectors that way and it works every time. As for the chart, that's what RCCA says, not me."
ORIGINAL: Dokioto
You will be able to do it.
It is very esay....
It is very esay....
) and try to keep it as far away from where you are working because often times the heat shrink will shrink on the wire due to the heat from the soldering!
MI
ORIGINAL: R/C fan-addict
And get one of these:
Really helpfull for soldering deans connectors on!
