RCU Forums - View Single Post - CAP 232 -66" from Giant Scale
Old 02-04-2003 | 10:43 PM
Dogz
Default CAP 232 -66" from Giant Scale
I don't think it will be ready by Saturday..
Update.... I put the battery just behind the fire wall and the receiver in the other small bay behind the first one. I mounted a JR 371 micro receiver on the side wall just behind the fire wall to run the throttle and it works well, tidy to.
I'm just waiting on a work buddy to cut and weld the muffler outlet to kick it out 30 degrees so I can direct the exhaust out the bottom center.
CG at the moment with no weight and 99% complete is at about 160mm. I want to bring the CG to 140 at least.
I was going to use flat car wheel weights they use for balancing and screw about 100- 150 grams to the fire wall.
