RE: More Matrix problems
Here's a dumb question.. Have you trued to return the carb back to the baseline factory settings? I have found on most engines will start on the base settings. Also double check that your fuel system is getting fuel to the carb....at the same time check fuel system does not have air leaks
hope this helps
