RE: Priming problems Genesis
i had the same problem in the beginning, you need to remove the air filter and check your gap for the idle if its too small then no fuel will be getting in. also i found that you may need to, while priming, hold the throttle wide open untill you see fuel go into the carb then install the glow heater, it should start after that. also the lsn if too lean will cause hard starts.
