RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 01-21-2007 | 10:07 AM
  #958
rhklenke's Avatar
rhklenke
My Feedback: (24)
Default RE: Nitro models pusher Bobcat?
Randy,
Be advised that there is an extra block in the front of the landing gear block (on top inside the wing) that the original hole goes into. There may be a problem with the stability of the gear in the way you swapped it around. Also, I would add some additional glue to the stock blocks before I used them. When I took mine out to put in the retracts, there wasn't much in there...
Bob
