RE: Tiger 60 Build Thread
Looking good. Interesting coincidence that the same day you post about having to sheet your trailing edges, I was doing the same thing today. My ailerons are too thin to get by with sanding down the wing t.e. so I'm having to enlarge them as well. [:@]
Are you planning to use the 2.5" fiberglass tape that came in the kit for the wing center section? I'm torn between using the 2.5 or going with 4" to span the fuselage width.
