RCU Forums - View Single Post - Lancair 360 MK2
Old 01-22-2007 | 12:50 AM
virtualvictum
Default RE: Lancair 360 MK2
I will try to post pictures. The c.g. I am using is 72mm spot on on the great planes c.g. machine. The elevator has 8mm of movement both directions. The ailerons 10mm both directions. Max throw on the rudder. Believe me that is more than enough to control it. This provides very good roll rate and believe it or not tight loops if you want to.
ID:	603896   Click image for larger version
ID:	603897   Click image for larger version
ID:	603898   Click image for larger version
ID:	603899   Click image for larger version
