RCU Forums - View Single Post - Four engine model
Old 01-22-2007 | 10:52 PM
  #76
Terror Dactyl's Avatar
Terror Dactyl
Default RE: Four engine model
ORIGINAL: twinman
BillS
Saw your idea on the four engine Pheonix.
Check the picture attached. Something like that??? The plane weighs 6.5 pounds empty,,four .32's?? or LA 40's??
The nacelles can be moved in and glued closer, but the original screws for mounting will not have much to grab...Uh..If you cut into the wing..under the nacelle mount, where could not be seen, you could install blind nuts inside the wing, bolt and glue then!! Mmmm
Twinman
PS,,no, at this time building as twin, but...
http://image.rcuniverse.com/forum/up...73/Om33706.jpg
I notice that you did not say anything at the time or I would have tried to get you to try a twin BV-141B which have meant the elevator would have to be offset to about 75-80% on the opposite side of the rudder from the engines
but you could still do it on the latest bird you are doing???
