RCU Forums - View Single Post - Sig Kadet Senior
Old 01-23-2007 | 10:39 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Sig Kadet Senior
I too recomend the Kadet Sr.; but also recomend you do not mount the camera as though you were "sitting in the cockpit" as it will result in really boring video of a lot of sky and some weird lines from the prop spinning. A modified pod on the belly between the main gear pointing the lens forward and slightly down will let you see more terain.
