RCU Forums - View Single Post - Sig Kadet Senior
Old 01-24-2007 | 07:32 AM
SebM
Default RE: Sig Kadet Senior
ORIGINAL: Mr67Stang
I too recomend the Kadet Sr.; but also recomend you do not mount the camera as though you were "sitting in the cockpit" as it will result in really boring video of a lot of sky and some weird lines from the prop spinning. A modified pod on the belly between the main gear pointing the lens forward and slightly down will let you see more terain.
That is interesting comments about the position of the camera. I never though about that. I wanted to install it into the cockpit to have the same view as the pilot. The reason is I'd like in the future to pilot it with the view of the camera, the position is important for this matter. If you want to have an idea of what I'd like to setup take a look at this video : http://video.google.fr/videoplay?doc...94150645963232 I just saw a closer picture of the Senior and the motor is right in front of the cockpit so effectively the view from the camera would be compromise. That's what I liked a lot about the H9 Cub, the cockpit is very big and clear with only the prop in the view which is not really a problem. Now it bring me one more question :
If I can install the camera on the belly ( considering it could work to pilot with this view ) and if I don't really need anymore a plane with a clear cockpit ( I said canopy in my first post but it look like an error from my poor english ) what about getting the LT-40 ARF ? It's more than $100 less. Is the Senior really better ?
Thanks everyone for the response. I'm surprise that nobody mention the others two planes
