ORIGINAL: Neriyah
Thought about that, but the housing seems very thin around the screw, rather take some off the ring...
TRDs first answer, is right again & so are you.
I had the same problem when fitting one to my Gen LE. I also removed a minimal amount from the manifold ring. That was 9 months ago, still no ill effects caused by doing it.
Regards, .46NitroAddict [>:]
