GST & Roto start
Any of you have problems with rotostart backplate not fitting ? Mine hits the ring on exhaust maniford (where the spring attaches to) I could ofc just gring a few mm off the manifold ring but is there another solution ?
ORIGINAL: Neriyah
Thought about that, but the housing seems very thin around the screw, rather take some off the ring...
I had the same problem when fitting one to my Gen LE. I also removed a minimal amount from the manifold ring. That was 9 months ago, still no ill effects caused by doing it.
Regards, .46NitroAddict [>:]
