RE: Sim for windows XP
Hi there Kevinator9
Thank you kindly for going through all that info for me I'm sure it will be of use to alot of other people too. I've been through everything step by step as you said, but I've a problem after changing the 'serial Protocol' as is won't change from "Waiting for stream init" to "Reading Serial" so I'm guessing that there's a problem with the Serial cable supplied be Walkera or the 'Serial to USB" adaptor isn't compatable. So I'll look into finding one of the newer cables I've read about on the internet. Or maybe try my Hitec TX.
Thank you once again for your help
