Q40 mount bolt pattern
Regarding the pre-drilled aluminum Q40 motormount with 3 firewall mounting holes on the ring. Can you tell me the hole center dimensions that the bolt pattern is manufactured to? ie, are they a radial/angular dimension from the center of the ring or some nominal horiz/vert distance apart? Im trying to daw up a cad template to match.
