Dub Jett Engines Support Bob Brassel of Dub Jett Engines provides direct support here for Jett Engines.
Q40 mount bolt pattern
Old 01-24-2007 | 02:30 PM
Default Q40 mount bolt pattern
Regarding the pre-drilled aluminum Q40 motormount with 3 firewall mounting holes on the ring. Can you tell me the hole center dimensions that the bolt pattern is manufactured to? ie, are they a radial/angular dimension from the center of the ring or some nominal horiz/vert distance apart? Im trying to daw up a cad template to match.
Old 01-24-2007 | 04:15 PM
bob27s's Avatar
My Feedback: (19)
Default RE: Q40 mount bolt pattern
Let me check on the information.....
Bob
