RE: Tire Recomendations for WarHead??
If any of you guys plan to run the Revo wheel and tire setup, just be aware of the offset difference. They will decrease the track width of other MTs, and can cause things like shock and knuckle/tierod clearance issues. That's why the Pro-line Wabash is marketed as a Revo wheel, it has the same funky offset.
Besides, they are 14mm hex wheels. With the engines that some of us are running combined with the hefty weight of most of these MTs, there really is no excuse for running the weak little hex... much less wasting money on another set of 14mm hex wheels. Upgrade to 17mm or 23mm hubs instead, it's money WELL spent. Not only are you asking a lot of ANY 14mm hex setup, but some of the popular/desirable 14mm hex wheels are notoriously weak, like the Pro-line Velocities mentioned earlier. The 23mm Velocities seem to hold up much better.
