RE: O.S. 46 fx problems
G'day Mate,
Sounds like the idle mixture is too rich, lean it a small amount at a time & see the difference.
Be aware, as you lean the low speed the idle speed will increase, just as it does with a high speed adjustment, so you must slow it down by closing the throttle, a bit. Adjust until it picks up smoothly from slow idle.
