RE: setup question
Ballance is determined how you want it to handle. the farther back the more stable as far as ggoing straight but to far will make it want to blow over. The farther forward the loosser it'll be in turns (and funner too) and less apt to blow over. As far as thrust angle start at 0 and adjust from there to trim it. Rudder hinge line should be straight up to start with for yout first build.
