RE: 30.5cc Engine problems
Not sure how far you went "pulling down" your motor to clean it, but just for the heck of it, I would close the low needle (counting the turns so you know where your setting was/is), then remove it and check for debris and clean if necessary. Return to your original setting and try again.
