30.5cc Engine problems
Old 01-25-2007 | 11:56 PM
Default 30.5cc Engine problems
After the last run of my comanche, I pulled down the motor and give a good clean. Now that I have put back together the idle is rough, and as soon as I add any throttle it stalls. I have not touched any of the carb needles. Any ideas?
Old 01-26-2007 | 12:24 AM
Default RE: 30.5cc Engine problems
Three options. There's an air leak, the diaphragm is upside down, and the metering needle is not propely installed.
Old 01-26-2007 | 12:40 AM
Bass1's Avatar
Not sure how far you went "pulling down" your motor to clean it, but just for the heck of it, I would close the low needle (counting the turns so you know where your setting was/is), then remove it and check for debris and clean if necessary. Return to your original setting and try again.
Old 01-26-2007 | 12:44 AM
Air leak through the head gasket or carb?
Old 01-26-2007 | 03:45 AM
Have gone back and checked Diaphram, metering needle, and replaced head gasket, but still the problem exists.
