RCU Forums - View Single Post - Cen GST 7.7 3rd gear
Old 01-26-2007 | 10:26 AM
.46NitroAddict
Default RE: Cen GST 7.7 3rd gear
ORIGINAL: MONAROMAN
I cannot roll the car easily, gets caught/jolts then will roll semi freely. Is this normal? This is my first MT (with centre diff, 3 speed and reverse), was previously running mainly tourers (bit boring now I have my GST )
MM, check your brake discs, carefully check to see that the discs are not falling over slightly, causing the brake pads to bind. I had this problem on my LE, & it was caused by the pad retainer bolts being set too loose. I adjusted them up a little, which stopped the discs falling over (was only a couple of degrees from verticle - but enough to cause a tight spot), fixing the problem. I assume you have already checked wheel bearings, cdv's dogbones, etc.
Hope this helps, .46NitroAddict[>:]
