RCU Forums - View Single Post - can you mount an engine at a 45 degree angle?
Old 02-04-2003 | 08:08 PM
redneck
Default can you mount an engine at a 45 degree angle?
I had a Sig Kavalier with a K&B .45 mounted on 45 degrees just as you described. Worked great. I think inverted would be a lot of trouble getting to the glow plug to pre-heat it and to remove the pre-heater after starting. Any one know of a good remote glow-plug heater hook-up?
