I have three Dremels and use them all the time but I'm a tool nut the man that dies with the most tools and planes wins. I have them hanging above my head in my shop with the bit I use the most in each one. Those cut off wheels are the best you will find hundreds of uses for them I use them all the time and those little samding drums too.
ORIGINAL: tigerdude426
ORIGINAL: sticktickler
tigerdude426,
It should not affect the cradles at all but you may need to move the pump to the boxes rear.
I have no real knowledge that storing a sealed dry cell on its side does any harm I’m sure it make little difference. I have two batteries in my box just sitting in there no padding what so ever has been fine for years. If I was you I’d find a way to punch some holes in the divider so it can still vent on out the vents in the front and put them under the panel as they should be. A Dremel with a right angel cutter and one of those side cutting bits would cut some nice slots in it quick and easy.
I think its about time I get myself a Dremel tool and accessories. Something I should have gotten a long time ago. I bet when I get one I will wonder how I lived so long in this hobby without one.
