RE: need help with car
that clutch works but it gives a much higher stall rate so the clutch will not engage until higher rpm's but it does eliminate the spring. I switched back to the 4146x spring and stock shoes, just round the sharp edges with a file. the aluminum shoes work good with the hardened clutch bell.
