need help with car
need help with car
my when i crank my car the wheels spin really fast and the car revs high i have all the settings back to factory settings so i could retune it. today i put on my tigerdrive and cranked it up and the wheels are doing what i said spinning could it be a bad clutch ? when i was running it before it wasnt doing that at all i even tried to play with the idle screw and it didnt work ne help would be apprieciated
thanx ahead
dan
thanx ahead
dan
RE: need help with car
http://www2.towerhobbies.com/cgi-bin...?&I=LXUR89&P=7 get these cluch springs they hold well
i think i'm going to buy the teflon clutch shoes to replace the spring and the hpi clutch bell to replace everything in the whole shabang
has anyone used the teflon clutch shoes hpi #A886: [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXVK12&P=7[/link] and will they fit with the hpi bell for the 2 speed
i just took my car apart the clutch is not round squared on the edges
that clutch works but it gives a much higher stall rate so the clutch will not engage until higher rpm's but it does eliminate the spring. I switched back to the 4146x spring and stock shoes, just round the sharp edges with a file. the aluminum shoes work good with the hardened clutch bell.
