RE: Ballistic Ship... NEEDS ID ?
Here you go. The glass work looks good (no pin holes) and
the fuse weight is about the same as a Tiporare. On the one
I have the fuse will need a some filling of the seam between
the canopy front and the spinner ring. The wing and stab are
per-sheeted with balsa with precut dihedral and anhedral angles.
Here are the converted specs. (may be off a little)
Wing span 62.992 in. (measured 62.5 with tip blocks)
Length 56.692 in.
Area 874 sq. in. (looks more like 674-774)
Weight 7.495 lbs.
Ron
Forgot to add. This is one of two kits that showed up on ebay.
Not sure if it is still available from the maker. Looks like it
should be a good flyer.
