RE: gst 2nd gears steers left
sorry guys i forgot to say but mine are set at 2-1/2 degrees toe out /__\ all the way around. world of difference if you want to go straight. and to answer the other question of a broken outdrive anything , on these trucks with a center diff if one outdrive fails its dead in the dirt, unless you have the center diff locked then you could possibly have front or rear wheel drive.
