RCU Forums - View Single Post - How much does your Lanier Edge weigh?
Old 02-13-2002 | 07:04 PM
SLC
Default LANIER EDGE
HEY LV2RCAV8. I'M FLYING MINE WITH A SIMILAR SETUP TO YOURS. MINE CAME OUT TO 12 LBS 15 OZ WITH NO LEAD. I HAVE THE BRISON 2.4 IN MINE WITH IGNITION AND 800MH NICAD MOUNTED INSIDE TO SIDES OF MOTOR BOX. 16 OZ TANK IS BUTTED UP AGAINST WING TUBE, RECEIVER MOUNTED TO BULKHEAD BEHIND WING TUBE, AND 1400MH 5CELL PACK IN FRONT OF BULKEAD WHERE TURTLEDECK STARTS. I USED A HAIGH STYLE TAILWHEEL AND STOCK MAIN GEAR. CG IS SET AT
5 1/8 FOR 3D FLYING. I WEIGHED MINE ON AN OLD ANALOG POSTAL SCALE SO WEIGHT SHOULD BE CLOSE. WHAT AN AWESOME COMBO! DID YOU EPOXY YOUR STAB ON AND COULD THIS ACCOUNT FOR EXTRA WIEGHT IN THE TAIL?
