RCU Forums - View Single Post - A NEW KIND OF BUILD THREAD, for those of you . . .
Old 01-27-2007 | 10:50 PM
  #88
shd3920
Default RE: A NEW KIND OF BUILD THREAD, for those of you . . .
FINALLY the last two drawers (middle and bottom) filed down to fit in the openings.
The two battery cover rails (used hardwood instead of balsa) are glued and clamped in place.
How do you attach the Hobbico Field Charger to the flight box opening? Do you simply use velcro or ???
Cover rails dry and battery cover (cut to shape earlier to fit the booboo mentioned above) fits perfectly in place.
Sticktickler - How are the cradle pieces coming? Did you receive the Money Order yet?
Later all
QUESTION: When the final sand is accomplished do I want all of the black lasercut marks sanded off or will it look OK if I leave some of them???
