RCU Forums - View Single Post - A NEW KIND OF BUILD THREAD, for those of you . . .
Old 01-28-2007 | 12:07 AM
  #90
shd3920
Default RE: A NEW KIND OF BUILD THREAD, for those of you . . .
The drawer secure dowel is waiting to be cut to size and the handle to be glued on. I guess I will try to find a round wooden drawer knob or similar for that. The holes were drilled relatively straight through all the drawers (well enough that the drawers aren't crookedly placed anyways )
I guess my flight box is just about finished (did I miss anything?)
A bunch of sanding to do now [:'(]. Start with 50grit sandpaper I guess for the rough stuff, then go down to 80grit, then 120grit, then 320grit. Will that be enough or will I need to end it with something like 400grit?
I will not be doing much sanding around the "SIG" logo as I would like to keep that if I can
See yah later.
