RCU Forums - View Single Post - Dual Aileron Servos - Y Cable or Not?
Old 01-28-2007 | 06:00 PM
Blue_Moon_'s Avatar
Blue_Moon_
Default RE: Dual Aileron Servos - Y Cable or Not?
If you are able to skip the Y cabel (depends on your radio), do it. It is mucho better to have them on seperate channels. That way you can for example use flaperons (ailerons center posision moves down to increase lift), you can also trim your ailerons more precisely with your twin channel setup.
May your skies be blue and your crosswind light
BM
