RCU Forums - View Single Post - Dual Aileron Servos - Y Cable or Not?
Old 01-28-2007 | 08:40 PM
bruce88123
Default RE: Dual Aileron Servos - Y Cable or Not?
ORIGINAL: gms
Building my first ARFs, after having spent many years with Hobbyzone RTF's on the 27Mhz channel. I just recently purchased a 6 channel Futaba Radio (EXAS).
Because it is winter here, I'm working on my second model (first was a GWS Beaver) and it has rudder, elevator and requires two servos for the ailerons (one for each wing). The manual with the radio is not clear for me regarding the following:
- Do I need to have a Y cable for the ailerons and route it to a single channel on the Futaba receiver, or is this only for people with 4 channel radios?
- Would using the Flaperon Mixing option (Channel 6 and Channel 1) have the same effect as the Y Cable....but obviously requiring me to have a 6 channel receiver?
When using a Y Cable on 1 channel (i.e. channel 1), do both ailerons move in opposite directions when moving the stick left to right?
Any help would be appreciated.
You may do it either way, your preference. Trimming ch 6 would have to be done with sub trim I believe and it would not respond to changes in the ail trim.
When using the Y-cable they will operate in opposite directions IF you do the mechanical linkage correct. THIS is one place using 2 channels could help because you could reverse just one servo if needed.
